Confused
Tuney
When I turn my key to start my car the starter turns but the motor doesn't any sugestions
so you see no motion of the engine belts while the starter is turning?
if so, you starter bendix gear is not extending and you should have the starter tested.
Starter is fine so I had my wife turn it over while I watched to see if the flywheel turned with the starter it does but the motor doesn't turn over
You either have no spark or no gas. When you place the key in the run position without trying to start it do you hear the fuel pump run for a few seconds?
The motor doesn't even turn over just the starte and flywheel turn
that doesn't make too much sense. How can you even see the flywheel, it is inside the transmission bell housing.
If the starter is turning and you see no movement of the serpentine belt, remove the starter and have it tested
I took the plastic dust cover that bolts on the bellhousing off and I can see the flywheel it turns with the starter but the serpentine belt doesn't move
the flywheel is no longer attached to the crankshaft. All the bolts have either fallen out or broken, not too common a problem unless someone did work on the trani and didnt tighten the bolts correctly.
