Sniperskills
- Apr 5, 2012
Hey guys I have a 2002 Chevy Suburban and I wanted to take off the engine fan so I can get rid of some noise. If I take it off will it affect the truck at all?
But new suburbans dont come with a fanyes, it will overheat, what did you think its function is?
check out the hood of a new suburbanIt's electric. but it still has a fan.
Is this a joke or are you serious??
The 2007 and newer Sub's and Tahoe's do not have a fan attached to the water pump. However, they have two electric fans controlled by a thermo switch or the A/C. If you remove the fan from your rig, it'll overheat pronto. If you want to remove the fan and go with an electric fan, Hayden makes an aftermarket electric fan that works pretty good. You may need two of their heavy-duty truck fans to do the work of the one fan you have now. Good luck.
