Hello
I have a 2004 Suburban 5.3 4x4. I installed a new power steering pump, steering gear box and pittman arm. After starting the car and driving for a a bit, the Service Stability light comes on. The OBD shows code C0455 which says to inspect the Steering Wheel Position Senor. I have checked the sensor and it appears to be normal. The terminal is not bent and the connection is good.
I am cautious about replacing this sensor as I did not have this problem before I replace the pump and gearbox, so I fear it may be a red herring.
Any advice is appreciated.
Thanks
Jonathan
Thanks
Jonathan
