Z Zimcocomp Member Joined Nov 1, 2010 Messages 30 Reaction score 0 Points 6 Mar 8, 2019 #1 The rear hatch lifts some times with three tries before failing. Gets a little better if it's a little warmer out. What might this this be.
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Mar 9, 2019 #2 if you are referring to the gas lift supports they will lose some strength in cold weather because the gas pressure drops. If they get to the point that they will no longer work correctly regardless of temperature they have to be replaced.
Z Zimcocomp Member Joined Nov 1, 2010 Messages 30 Reaction score 0 Points 6 Jun 29, 2019 #3 No it's a power liftgate. It will also sag back down till closed.
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Jun 29, 2019 #4 open the panel and check the motor and gear mechanism https://www.youtube.com/watch?v=J-AAVvMrfvA
Z Zimcocomp Member Joined Nov 1, 2010 Messages 30 Reaction score 0 Points 6 Jul 8, 2019 #5 Replaced both gas assist pistons and all is well. Thank you all.
