will this fit my nova
Yes the seller I found non eBay wouldn't ship it to me so I have tht site you suggested or eBay funding it new
The abs plastic headliners are not a perfect fit. It will need to be trimmed along all the edges, it may be a little thicker too. Most of the used GM headliners I have found were very brittle. I finally located a good one 2 years ago in a hatchback from San Diego. It was the standard perforated press board. I covered it with headliner fabric that was foam backed before installing it.
Stock interiors sells the ABS, no one I know of makes the original press board. Because it comes covered with fabric and foam trimming will be difficult.
Quote from Stock Interiors website
Stock Interiors is proud to offer the highest quality Chevy Nova Headliner Replacements available. Our Headliner boards are made to fit just like the original, but are made of ABS plastic which is much more durable than the original pressed cardboard composite board. The plastic board is vaccuum molded to the same shape as your original Chevy Nova board, and will not warp or absorb moisture resulting in a headliner that will look as good as your original! Each headliner is covered with foam-backed material in the color of your choice and has a lifetime guarantee on the plastic and 1 year on the foam backed material.
This item fits the following years: 1975, 1976, 1977, 1978, 1979
Did you ever buy a headliner? If so how did it fit?
The ebay one in the link is ABS also
You are buying a brand new, custom fit headliner board for a 75-79 Chevy Nova 2 Door Sedan or Hatchback (With Seat Belt Retractor). The headliner board will be custom made after the auction ends.
Stock Interiors is proud to offer the highest quality Headliner Replacement kits available. Our Headliner Kits are made to fit just like the original, but are made of ABS plastic which is much more durable than the original pressed or paper board. The plastic board is molded to the same shape as your original board, and will not warp or absorb moisture resulting in a headliner that will look as good as your original!
