I noticed it seemed to miss a cylinder a while back, especially when it would rain. A couple months ago it rained almost two weeks straight. One morning on the way to work it seemed to miss very badly but still did fine. When I got off work I turned it on and it didn't want to start. Eventually it started but seemed like it was only running on 3 or 4 of the six cylinders. After gassing it a lot it got to where it would idle around 600rpms. I made it home like that and parked it. Waited for money for parts and changed the plugs and wires. it wouldn't start anymore. I then changed the distributor and button and the battery. No change other than a peppier starter. I then changed the ignition control module. Now it seems a little more inclined to think about starting but still doesn't. While changing the distributor and button I completely removed the who distributor assembly. I notice a notch on the bottom an seated it flushly down into the block. I assumed the notch made it impossible to improperly seat the distributor assembly.
Any ideas on things I can check or try would be greatly appreciated. Email me from my "Profile" page if you need any more information. Please help me.
