timing, 81 chevy malibu 350?
frost1085
if i turn the balancer mark to top dead center is the distributer rotor sapposed to be facing the #1 spark plug
(i rotated it with little cranks of the engine, then when it was close i put it in nuetral then turned it by hand to make it perfect)
Either there, or #6 spark plug.
Depends if #1 piston is at the end of the compression stroke or the end of the exhaust stroke.
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/07/a1/5c/medium/0900c1528007a15c.gif
Yes the rotor should be pointed towards the #1 Sparkplug terminal on the cap. After installing the distributor be sure to check the timing and adjust to specs. Good luck and hope this helps.
You'll need a correct length timing tape for your outside diameter harmonic balancer. MSD sells these. The ignition timing has to be set with an inductive timing light @ no more than 32 crankshaft degrees after the flyweights under the cap have swung out to ther maximum travel. Usually the motor has to be spun-up to at least 3,250 rpm.
The vacuum source at the vacuum advance canister has to be plugged-off
