The power ban of 96-00 5.7l vortec in 96-00 gmc sierra chevrolet silverado?
Darkhouse
What power doees it have explain please what i mean is low-end midrange high-end what do those mean and what does the vortec have of those?
The 'power band' is a section of the engine rpm range where the engine produces the most power.
The '96-00 5.7L engine is rated at 255hp (4600) and 330ft-lb (2800) at the flywheel.
Clink on the link below, then select the graph for the L31 motor.
http://www.gearvendors.com/cghptorque.html
The L31 is the code for the 5.7L motor for the years listed above. You can also click on some of the others. Notice the difference in the graphs. For example, the 7.4L (454ci) has a flatter torque curve (the blue line). This means that the motor produces near peak torque across a greater range of engine speeds.
