Stupid A--
1995 K2500 Suburban [454 N]
I put new rad in plus new oil cooler lines. Lines are click/push in engine side. Oops didnt push hard enough. 500 yds from home popped off [first I knew no oil pressure] I limped home which by the time got in the driveway had the dreaded knocking. After seeing the 2ft wide swath of oil down the road knew it was bad.
So, question is, do I attempt to rebuild or just purchase a crate/reman engine.
If the latter, any suggestions on source.
Thanks in advance
Thanks in advance
