quick question about making my camaro sound louder?
tommaso
OK, I juts bought a 1999 Chevy Camaro and would like to make it sound louder. Here is what I heard may help and would like some suggestions.
1. flowmaster catback
2. set of headers
3. air intake
would these things make my car have that deep grumble and is it wort the money. I have around 1 grand to spend.
The air intake kit is more of a performance mod. I would do that along with the exhaust. A free breathing exhaust needs a free breathing intake. Are you doing all this yourself? If so, you should be able to get it done on your budget. Check Ebay for the filter kit. It's easy to install. I would go with KN. Another thing to consider are high flow cats. Again to accommodate the higher volume of air you're going to be moving. The factory cats are pretty restrictive. Good Luck.
if you shop around a flow master system would cost less than a grand it would give it a low rumble and a nice pitch when stomped on the air intake has little to do with an exhaust note but if you free up the back end you should let it breath better as well.. orrr for a drastic change straight pipes no mufler cat back
Intake won't affect the sound very much. Catback and long tube headers will get you where you want, but it'll probably set you over 1k. Get the catback first and see if you want it louder, also that'll allow you more money to save up for more to get the headers.
If you have a Z don't get a flowmaster catback...there are better catbacks out there that flow MUCH better and yield better power increases.
You're on the right track though(the intake won't help with the exhaust note though)
