Oil Pressure Gauge Question
NMC_EXP
Colorado
New to me '99 K1500 Suburban with 5.7L Vortec.
At highway speed the oil pressure gauge reads from 50 PSI to 25 PSI. It will stay in one spot for a while then the needle will jerk up and down thru a 20 PSI range. Then it will settle down for a while, probably at a different PSI from when the needle started jumping around.
Did the same thing, both before and after an oil & filter change.
I'm hoping it is a loose or dirty connection at the oil pressure sending unit.
I do not have a service manual yet - can someone tell me where the oil pressure sending unit is located on the 5.7?
Thanks
Jim
did you look right above the oil filter?
what do you mean "Not close enough"?
