So, tried to shift into 4WD and the 4WD does not lock in. The transfer case shifts correctly from high to low, I guess that's completely manual, but there is no indicator light on the shifter console and the 4WD does not engage. I checked the fuse panel -- the fuse 24 is OK. The t-case fuse (#2) is missing. I notice there is a slot for the #2 fuse, but there are no connectors in the holes. No fuse goes there -- must have been a design change somewhere along the line. What's up with that?
Couple of possibilities I suppose: bad switch, frozen actuator, broken wire?? Any wisdom from the Suburban people?
