I can't find my ground wire on a 2006 chevy cobalt?
Aaron
I'm trying to do some electrial wiring to my 2006 chevy cobalt and cannot find my ground wire. Does anyone know if they have one? or what I need to do?
Just find a screw or bolt and make sure there isn't any paint under it and screw/bolt down the wire that you need to ground. If you are doing wiring where there aren't any bolts around you can find part of the body/floor that is out of the way and scrape of the paint and use a self tapping metal screw, just make sure there isn't anything important under it.
Any point where metal meets metal will provide a sufficient ground.
I suggest a bolt.
Just make sure there is no paint or anything on it.
Buy a brand new metal bolt and remove a bolt anywhere there is a factory bolt and metal, scratch away the paint, but just in bolt area (sand is best!), ground ( keep wire short) and replace with new metal bolt! if you want an easier way, try grounding studs on ebay
http://cgi.ebay.com/ebaymotors/Black-Power-Distribution-Block-Dual-1-4-Studs_W0QQitemZ330306622234QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item4ce7cf131a&_trksid=p4506.m20.l1116
