you will need a proper connectors a fuel pressure tester all so how much the pump should put out ,locate the large fuel line on the back of the throttle body open the gas cap to vent any pressure remove the line install the connector connect the gage turn on the ignition get the reading if it is not with in tolerances replace the pump .
