How do you check the transmission fluid in a 99 chevy Malibu?
Ruby
As in, where is the dipstick located?
I know how to check transmission fluid in our other vehicles but we can't find the dipstick or even where we'd add the fluid
If it's an automatic trans., start the engine, set the brake and put it in neutral. check using the transmission dip stick. Shut it off to add, then restart to check again. Drive around to warm it up before you check it cause fluid expands when it heats up. If it's a manual trans, take out the fill bolt under your car on the side of your transmission. Just like a rear end, it should be full the the bottom of the fill hole.
crank car let run open hood pull dip stick look add if it needs
how to check transmission fluid video
