How do I use the generator feature in my 2006 Chevy Silverado Hybrid?
slyce476
I bought it used with 33,000 miles on it. I read the users manual but it doesn't even mention the fact that it's a hybrid. I can't find any literature on chevy's site on the generator and how to use it. Does anyone know??
The hybrid system GM put into your particular truck is a mild hybrid system, which has an oversized alternator built into the transmission flywheel housing. The Alternator's large size allows it to be used also as an engine starter motor to crank the engine.
That extra-large alternator can be turned by the running engine to generate a lot of electricity-- Enough to drive the four 120VAC outlets in the back.
If you want to use the 120VAC outlets in your Silverado, you leave the car running and plug in your electrical appliance. The engine will spin up the alternator to produce the 120VAC power whenever it's needed.
Hope this helps.
