How do I add transmission fluid in a 2005 Chevy Malibu Classic?
Steve V
i busted the radaitor and lost some trany fluid i need to add more there is no dip stick its one of those that chevy dont want you to check
i found the plug and it is tiny gonna be hard to get fluid in there can i just force fluid into the hoses tha connect to the radiator
are you f%@$#% retarted? how would you lose transmission fluid when you busted your radiator? Come on now, guy. Take the car to a mechanic, because you obviously have no clue what you are doing.
hey jack donky evey one knows that the trany fluid is cooled in the radiator when i busted the ratiator i also busted a the radiator cooling system so next time think before you speak and clearly you have no clue
There's a plug in the hole the dipstick used to plug into.Its usually along the edge where the transmission pan bolts up.The plug itself has a small dipstick on it.
plug in/on side of tranny...no wonder GM is going down the crapper
