How do i add more HP to my 267 1980 Camaro Rally sport without replacing the engine?
jeff
i want more HP to my 267 small block and i dont have the money to buy a 305 or 350. what else can i do to increase the HP?
If you want to go fast without adding more hp best thing to do is put smaller tires, in height it cheaper just go to your local tire shop and try out some used tires. if you got any other questions email me at sidis76nova@yahoo.com
Well my friend you need to upgrade the Intake, get bigger fuel injectors or carb whatever you have., installing 1.7 roller rockers will give you more lift on your cam *its complicated on how it works but it will give you more lift*. Change out your cam with a hot cam. Port and polish your heads, or replace them with new aluminum ones. You can change the pistons and add more compression. I would bump it up to about 10.5 or 11
