Ok, so I have a 1998 Chevy Silverado. The first problem I had was the oil pressure gauge would constantly bottom out, in which would cause my check gauges light to come on. Also, my temp gauge stopped going past the first solid line. These 2 gauges were always basically straight up and down. The oil pressure was right at 40 and would drop a little when stopping. The temp gauge was usually one tick mark below 210.
I started with the oil since I started noticing oil on the ground under the truck. Ok so I had an oil leak at the oil filter housing. I fixed that. Oil leak is gone and it's maintaining oil amount. I also replaced the oil pressure sensor. My oil gauge does the same thing. It reads low and bottoms out.
Temp issue. I started with thermostat thinking it was stuck open. No change. I changed BOTH temp sensors. No change in gauge. I then ordered a new cluster. Well guess what , those 2 gauges read the same as my original one did.
I did live data and my temp shows it's hanging about 193. Yet no matter what I do the gauge never shows that !! Nothing has fixed the two gauges reading right.
I am stumped. I have no idea what else to do!
I forgot about saying i did these things as well. I ran a coolant flush. I also went ahead and replaced the radiator since I had drained it and it was a little rusty and nasty looking. While everything was apart I also replaced the fan clutch. It had a little play in it.
It's so weird, according to live data my temp is ok. I just can't handle the temp gauge only half working. It also bothers me that I don't know if my oil pressure will be ok with the gauge not working. I have had this truck so long and would hate when something happens and I have to park it for good.
Any ideas out there. ?
