don't know what I did :( help
Sorry for the absence, I found the problem. It was actually a wire that powers the fuel pump relay, the oil pressure switch and feeds power to the ecm all at the same time. Found it and splices it intobthe battery and Vrooom! Aahahahahaaaa! But....lol. like a jacka** I broke the seal on the throttle body and it was spraying gas everywhere.. (like a noob). Anyway I tracked down a new body (possibly the last one for sale in this country) and installed it. Now the engine cranks up and runsjust fine but it is idling very high now. I believe the ecm needs to re-learn the throttle position but not too sure about that. I can't drive it because the exhaust manifold gets waytoo hot . I'm talking its glowing red in about 40 seconds. So..plugged catalytic converter? Map sensor for the throttle body? I have no idea.
remove the converter if you dont need it and did you adjust the throttle position sensor?
