Alright guys hope some one could help me out.
I have code 45 with truck using way way to much fuel. Truck is a 88 305 TBI that was rebuilt about 4-5 years ago (about 100-120k on it now).
I have done and replaced the following:
Temp sensor
EGR
Cap/rotor, spark plug/wires
EGR Vacuum Solenoid
Map
Rebuilt TBI
O2 sensor
Coil
Fuel pump
fuel filter
I have sprayed carb cleaner all around intake manifold, vac lines etc with no change to trucks idle.
What truck does:
The truck surges at idle and good amount of vibration(truck shacking/vibrating like).
Idles around 500-600 rmp(some times it jumps around from 1k to 500 rpm at idle).
Truck bogs down during acceleration, and some times with you floor it it bogs(like to to much fuel i guess).
I have checked timing and its where GM says it should be, but some times when checking it at idle it jumps around.
Hope i give enough info for some one to give a guess or 2, I'm at a lose.
Thanks
Temp sensor
EGR
EGR Vacuum Solenoid
Map
Rebuilt TBI
O2 sensor
Coil
Fuel pump
fuel filter
What truck does:
Thanks
