Chevrolet Cavalier 2004, when i open the door the accesories dont stop?
RaDazZ
i haave tis 2004 chevrolet cavalier and when u take the keys off the egnition, the radio accesories are still on, but when u open the door they are supposed to turn all off. But when i open my door they dont go off and i dont want to run my battery off power. any one have an idea of what could cause that or how to solve it?
Description and Operation
Notes
SERIAL DATA CONTROLLED RETAINED ACCESSORY POWER, RAP
Retained accessory power, RAP is a vehicle power mode that permits the operation of selected customer convenience items after the ignition switch is turned OFF. These selected items will remain in operation until a passenger compartment door is opened or until the RAP function timer reaches its shut-off limit.
The Audio system on this vehicle is the only device that is controlled by RAP.
SERIAL DATA CONTROL OF RETAINED ACCESSORY POWER, RAP
The Radio receives a RAP message from the Body Control Module, BCM over the serial data circuits. The BCM module monitors the ignition switch position, battery condition and passenger compartment door status to determine whether RAP should be initiated. The BCM module then sends a message to the Radio telling it that it is in RAP power mode.
RAP will end when one of the following conditions are met:
The BCM module receives an input from the drivers door jam switch.
The BCM module receives a message from its internal timer indicating the end of the RAP period after 10 minutes .
The BCM module detects a decrease in battery capacity below a prescribed limit.
The transition from OFF to RUN/ON or ACC of the ignition switch.
The BCM module then sends a serial data message to the Radio ending the RAP function.
Chances are you have a bad door jam switch or a bad body control module.The BCM will have to be programmed at the dealer after replacement.
