2003 Suburban LT 4wd. 225k
So I replaced tie rod ends, Putnam arm, idler arm and the thing that attaches to on the frame. I also put new skyjacker front shocks, and replaced the premium smooth ride suspension with Bilistien springs and ranchero shocks.
Following the front end parts I had more bump feed back from the steering and that is why I replaced the suspension stuff and they were worn anyway.
This thing now rides worse than it did before all the repairs. I have to really pay attention to the road because it will spring one way or the other on road bumps.
I need some suggestions, one thing of note. The front is resting on the bump stop and I don't recall if it was before. I am wondering as well if it is possible the idler and pitman are wrong sized would cause such a thing. The only other issue is if the tortion bars are worn would this cause the symtoms?
Thanks in advance!
Thanks in advance!
