'99 Suburban power window issue
3thumbs
I have a '99 Suburban, and the front passenger window will roll up and down fine from the driver's panel but not from the passenger panel. I think it may be the switch in the passenger panel, but I don't know how to test it as there are several terminals for both the lock and the window. The lock works fine. I really don't want to repair this by buying parts until one of them fixes the problem.
Any ideas?
Thanks,
DM
Check your fuse box first and make sure that each window doesn't have an individual fuse for it. Sometimes it's that simple. If not, then you're going to need to pull the switch and test it at least. See if it has power to it. If so, then it would seem you'll need a new switch.
