I have a 98 cavalier automatic. The speedometer over a few month period stopped working and the odometer isn't working either. I have replaced the vss and nothing changed. I then replaced the speedometer with one from a junk yard and nothing changed( had issues with the anti theft, but was able to start the car and unplug the old and plug in the new and it did not work). I have inspected the wiring harness to the best of my ability and can find no visual issues with the harness. Can someone help? How can I test the wires to see if there is a short in them. The connector going to the vss has a purple and a yellow wire. Is there an easy way to trouble shoot them. The purple wire has continuity if I hold a multi meter to it and the frame of the car. Is that correct. I am at my wits end with this issue. The car shifts fine, I also disconnected the sensor and drove it and no codes or change in the vehicles condition. Any info or instructions will be helpful.
