97 cavalier front end noise/vibration
posfunfire
Soooo, I recently (last 4ish months) did my front wheel bearings, brakes, basically ive done the whole bottom end so far.
after doing the bearings all noises and shaking stopped, however a "distant" growl started after about a month and has gotten worse by the day. I had my mechanic under the front AGAIN and he did the passenger inner/outer tie rod ends, a HUGE chunk of the vibration is now gone.
my question is since my "growl" is constant and actually ONLY goes away when turning right, and the vibration (with a "clunking") is worse when turning left, should I be looking at my cv's , bearings again, or *as suggested* the tranny (some bearing bs) :confused:
any input would be great.
I would suspect CV joint
Ditto what Zora said. I'd just replace both front axles if I were you. You can get them at Autozone for about sixty bucks each.
