94 Burb Brake Bleed Question
rickbert
Just east of KC Missouri
Got all new hardware all around....shoes/drums/cylinder, calipers/rotors/pads....
Now to the bleeding.....
I understand if you think you may have allowed are into the master then you loosen the fittings into the master a bit then have someone push the brake pedal, close fittings, let of pedal.....do this a few times.
Then bleed each wheel from farthest rr, lr, rf, lf.
My question is do I do the bleeding with the engine running or without ???
Thanks
does the vehicle have ABS, if so may be more complicated if you let air into system. Why are you replacing cylinders, do you have a leak?
