Studeclunker
- Sep 8, 2023
I have been given a '91 S10 Blazer (4 dr) that is destined for a frame-over of a '64 Studebaker Champ pickup. I've taken measurements and am pretty sure that the old Studee will fit. Likewise it has the firewall brake cylinder and should work with the Chevy brakes. Likewise the Studee has the small block V8 (actually it's a Packardbaker motor) so the 350 should work in the engine compartment. My friend tells me that I can also switch out the V6 with a V8, in this case a 350. He says that the V6 is adapted from the V8 block and the transmission along with the flex-plate and Torque Converter should just bolt up. I was wondering if anyone here has any experience with putting a V8 to the S10 transmission and if it can handle the larger engine. My evil plan for this is to use it as a tow vehicle for my Spartanette (30-ft) trailer. It's less than 6k lbs loaded so the chassis and drive train should be able to handle it, to my limited experience. This old Blazer was rolled and the previous owner removed all the doors and roof to play with it off road.
Yes, I know the limitations for towing such a large trailer with such a small pickup. I have a larger truck to haul the trailer over mountains and such (also a Chevy, by the way). Just in case anyone might be concerned.
So, just to recap:
Is is possible to switch the V6 with a small block V8?
Will the S10 transmission handle the V8?
Will the drive train work without a computer, specifically the transmission?
etc...
So, just to recap:
etc...
