No transmission is attached dowel pins are perfect aligned no instruction and I had put pilot bushing over the input shaft before installing it in end of crankshaft, but somthing has got to be offi even went back with bottoming tap and checked all the the bolt holes in block and made sure no wires or hoses got in between, then checked all the threads on all belhousing bolts and screwed em into a die, it’s almost like input shaft is too long , to which I havnt checked the depth of end of crankshaft which is where I’m headed next wasn’t trying to go there if I don’t have to but at this point I see no other option
