Kx250gs1100@yahoo.com
- Nov 7, 2015
Had to use the 4wd this past weekend in the mud and my burb started making popping noises coming from the front end in 4wd. I was on soft muddy ground not hard ground when this happened. I read into another post about this and the guy ended up replacing his cv axels. So I ended up replacing both front axles with new ones. Well took it out and still having the same popping noise. Talked to a mechanic buddy of mine and he suggested the actuator was not properly locking in?? Does this sound possible?? And would that be causing that noise??
