2003 Malibu 3.1L leakin coolant
wpginterceptor1
my Daughter in law's malibu is leakin coolant from where the Bleeder assembly meets the water pump housing.. is there a gasket in there?? its NOT leaking directly at the bleeder but right where that whole piece meets the water pump housing!! Do I just remove it and use gasket maker and put it back or is there an O ring that needs replacing too??
PIC OF THE LEAK
anybody else have an issue with theirs leaking? was it just an ez oring replacement?
A seal after 20 years is not unusual to leak. If you are unsure about a successful repair try a professional.
I am a professional, thats why im askin if there is any tips on these, if its just the simple o-ring no problem
Here is a video where they remove the pipe assembly
