When I turn the key to the start position, everything on the dash does what it's supposed to do, but the starter does not make any noise at all. Have replaced ignition switch computer board, this did not correct the problem. If I hit the key repeatedly back and forth, eventually the starter will kick and start the truck. A mechanic tells me they believe it's a bad starter, but I have never seen a starter that doesn't make at least some noise. I would like another opinion.
Not as a rule, but sometimes, in the morning it starts right up, after it's driven and shut off, it won't start back up.
If I test this with a volt meter, do I test from the frame to the small wire on the solenoid?
