4wheelsteel
- Aug 12, 2016
- Age
- 31
I am having issues with my HVAC system. The rear AC is ice cold as it should be, the front USED to be ice cold but recently hasn't been. I took off the blend door actuator and it is functioning properly. I removed the cabin air filter and the air blowing over the coil is very hot, hotter than outside air. If I turn down the fan speed the coil cools right down. Can someone educate me on how this system works? It seems like the heater core is stuck open and the air is both being heated and cooled if that is even possible with this system. Any help would be appreciated. Thank you in advance.
