Well when i bought my truck it already had keyless entry on it. I don't know if it's is factory or aftermarket. It also has remote start installed which i know is aftermarket because these trucks did not have it as a option. The problem im having is the keyless transmitter will not set the alram and when you lock or unlock it the lights will flash but the horn will not toot. The horn does work. But the alarm will work if you lock the doors using the door lock button inside the truck. Also the keyless transmitter that came with the truck is a aftermarket one made by Pursuit. It has 4 buttons on it lock,unlock, one for the remote start/trunk lid opener and a option button. Any help would be greatly appreciated.
Ive tried hitting the lock button more than once before that doesn't work either, but thanks for trying to help.
