1998 Chevy malibu radio will not work?
Catrina
I recently changed my battery and a ton of problems started, The radio will not work and the little screen that shows when you switch into drive and other gears stays on. even when you turn off the car and have the key out of the ignition. and the airbag light stays on. This has never happened before. I have taken the radio out made sure everything was plugged in. Checked all fuses. Even replaced the radio and still havent found the problem. Could there be a short somewhere causein this to happen?
Leave it to GM, this is just one of the reasons why that auto maker is failing. Poor quality of the cars, and they can not see that.
You need to have the ecu reset. When you disconnected the battery it basically confused the ecu.
