1994 Suburban no power to ignition
Roelaux
I was driving to work and the engine shut down. Tried to restart no power to ignition switch, I have headlights bright and bright Interior lights. Thanks for the help.
You checked all fuses both underhood and interior? Can you test with voltmeter to see if starter solenoid gets power when key turned? Did you check owners manual for any relays marked as starter/ignition?
