1978 Suburban 4speed Manual : directionals failed.
Desert Suburban
Greetings All,
I just inherited my Fathers 1978 Suburban Custom Deluxe, It has lived in Bishop CA its entire life and is is great running condition. Yesterday the turn signals worked, today I tried to use the Hazard lights, they did not work and after the turn signals stopped working. Is there a "need to do maintenance" in a 38 yr old truck in the steering column to keep these connections working properly? Any advice would be greatly appreciated.
with respect,
Trey
sounds like the flasher died, check the fuses also
Sounds like a fuse blew.
Not an expert in these specific trucks but as zora implied: keep it simple, check the simple stuff first:
Bulbs
Fuse(s)
Flasher
Circuit Ground
Switch
