08 Suburban AC Clutch Relay
skeithline
For some reason, when I hook the battery up my AC clutch relay energizes. Key not even in the ignition. I unhooked the AC compressor and the relay still activates. Any ideas?
So this is the relay in the engine compartment fuse box?
What led you to finding this out?
Any modifications or accident history?
This is a 99 with a similar issue
It is in the engine compartment box. Figured this out when the battery was dead after sitting overnight. Had the engine replaced and the problem showed up. I've checked all of the grounds I believe.
Read post 3
