PtownBubba
- Dec 30, 2017
I am replacing the oem radio [ Delco 15071234 ] with an aftermarket one. I have the Scosche GM02B harness adapter,,,, I am trying to match up the GM colors with the adapter,,,,, it appears on the Burb the 12VDC switchable source is 'green', and says only for oem radio on code sheet I found. ????? Do I use that for new radio, or run a red wire to a switchable accessory point ???? and are all other connections, simply wire radio connector colors to Scosche adapter colors,,,, ?
