Will 1997 camaro ss (zr1 style) wheels fit on my 1995 corvette?
bulldog22
Found a local guy selling them cheap, not sure if theyll fit. Will i need spacers?
Also i'm wondering about the wheel size, ive had a few ppl tell me the ss wheels are 17x9 all around, and others say 16.
thx
he also has a set of 2000 ss zr1 wheels
They should be able to fit. go to the link below, or where ever this program puts it. It should tell ya if ya look around!
ya they'll fit, i've seen plenty of camaros with corvette rims on them all the time so it will work the other way around to, only problem that may come up would be if the rim clears the brake calipers the camaro rims are smaller than the corvette rims, if your not sure then im sure the seller of the camaro rims wouldn't mind you seeing if one of the rims fit on your vette, i'd test it on the front though since the front rotors and calipers are usually a little bigger, also since you have one on the front you can also test if you need spacers, just let the car down and turn the wheel both ways and stopping it on each side from lock to lock to test clearance issues
