It is at the lowest point on the bottom of the motor so it will all drain out..so crawl under there and find the part of the bottom of the engine that is closest to the ground...then scrape off some of the gunk with your fingers and you will feel the bolt head that you have to turn to the left counterclockwise.
"Righty tighty, lefty loosey"
Good luck!
