did you coat the bolts that go through the water pump with sealant to prevent them from leaking,if not its coming from one of the bolts that go through it,another possibility is the gasket got pinched on it and that may be whats making it leak,that or a pinch in a hose will cause it,you need to clean it off and see if you can locate it,good luck
