Where can I find new front bearings for 2003 Chevrolet Avalanche 1500 2WD?
Scott Brown
I need new bearings for my truck. Can someone give me like a website that sells these parts? Kinda on a small budget. Less than $100. I thinks the parts for both front wheels are around $50. Please no aftermarket manufactures, just genuine GM parts. Thanks for your help.
OK then, used parts that are in GOOD condition?
Not aftermarket...not going to happen. Sorry. The aftermarket stuff is in your budget the OEM GM parts are not.
you will not get them much cheaper online than you will from your local auto parts store.the few bucks you may save will get eaten up in shipping costs, buy a good quality set, from a better than oem manufacturer, or you will have the same problem, GM used cheap bearings, that had a coating over a softer metal, high quality bearings will be of a solid material they will last longer, hold up to heat better and the coating of one bearing coming off does not help degrade and ruin the rest, since a good quality set of bearings are not a cheap coated bearing, but made out of a high strength very durable metal.
