when to replace the steering gear box?
Meet07
Garner,NC
The 95 Suburban I recently purchased has 350+ miles on the body. After driving it the first time I noticed the steering wheel wasn't straight. I'm thinking no big deal it propably needs an alignment. Then I noticed the steering wheel has a bunch of play in it(@ least an inch withtires on the ground) I want to get an alignment but at the same time I don't want them telling me I need this and that. I'd Rather replace what's bad 1st. Wheel bearings on both fronts have more plan than I like so I know Im replacing both of them. Can anyone shed a little light on the situation? When should I replace the box? I've also tightened it but the steering just gets a little tighter. Still bunches of play.
Before tightening the box you should check tie rod ends, center link, idler arm, rag joint, etc. for being worn out. Overtightening the box can destroy it. Have you greased the box?
I didn't know the box could be greased. I bought a manual yesterday and read through it. Didn't say anything about greasing it. I did check the idler and pitman arms. According to the manual and videos on YouTube I didn't see any play. Tie rods look great. The boots aren't torn or anything. I did tighten the steering box, little by little.
try to have someone move the wheel back and forth while you observe the rod ends for excessive play
Yeah I did that yesterday. While in the air, had my old lady move the steering wheel back and forth (In a hand waving motion) and everything was tight. No play I. Any of the arms. Just play when on the ground. The steering wheels moves like 2 inches before the wheel even moves.
After doing a bit of research I'm convinced its the "rag joint" Seen a video that says an 90's model jeep Cherokee steering shaft would work. Supposedly doesn't have the rubber inserts that flexes. It uses a universal joint instead. I'm going to the local pick our part this weekend and see how it works!
