Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
at 10 mph and on it goes wonh wonh wonh etc. its not the axle because it not clicking or knocking i was told its the front drivers side wheel bearing( hub assembly) could this be true??
a bearing sound is usually a grinding sound. jack the car up and see if you can shake the tire in nd out. if you can then it,s safe to say you have a bad bearing. if you decide to change it, it,s best to buy the hub with the bearing already in it.
