I can't get the check engine light to go out. I've checked all the fuilds they are all good. I've put a new distributor cap, rotor and spark plugs. Then took it to a mechanic to change to oil because it smelt like gas they ran a diagnostic test on it and it came back says to change the ECM fuse which they did and then they ran it again and go a code 52 and they couldn't find what would cause that code. then after they put the ECM fuse in the car started to stall. they told us it could be something with the fuel pressure or something since my dad just put a new fuel pump in last weekend. so we took it home and checked the fuel pressure, pump and filter. there was nothing wrong with that.
does anyone have any ideas how to fix it
