Yes all fuses solid, and other then some softened gummie spots under the dash wiring they are fine.. some questionable spots right above and across brake and gas peddles looks tighter then it should..Did you check for blown fuses?
Did you check for blown fusible links?
I assume this is a 2005 Colorado?
What is done with the other non speaker wires, as the last owner apparently wired a few together, which I believe to be the cause to my constant power to the rear tail lights , and across to the passenger side... .. and leaving it as is and just taping it better.. left me with nothing up front. Only tail lights and over head bed light...I am assuming that is the "lan serial network" wire....i am not understanding the reasoning that Chevrolet has used on their wiring.
2005 Chevrolet Colorado Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Scosche Tech Accessories | #1 Mount Brand in US & Canada
Scosche Tech Accessories | #1 Mount Brand in US & Canadawww.scosche.com
I didnt install it, it came as is... all I did was replace new tape so the wires was sealed better.. saw whomever did it wired together the ones that didnt into the deck..Did everything work before you tried to install the radio?
That's just it, I know better.. but kept everything how it was, retaped, shouldn't have been any issues 3 mechanics clarified so.. psh... I know the acc red, the 12v yellow, and ground black/white... blue is remote truck doesnt have that or a 12v constant allegedly, the deck red and yellow wires run into the trucks orange power wire used for original system..You need a wiring diagram for the radio you are working with. If you didnt have these issues before trying to retape everything you miswired something.
