were is fuel filter 2003 chevy malibu gets no gas?
MR. T.
the car ran out of gas now after gas in it won't start
check the pump by takeing your back seat out and there should be a cover that has 4 screws on it thats where the fuel pump is take the cover off and have someone turn the key on and off every few secs and see if you hear the pump running dont start the car just turn the key on and you have a screen on the fuel sending unit check that to make sure there is no build up around it to get to it look under that cover i was talking about and there is a round lock ring that goes around the top of your sending unit take the lock out by turning it and then just lift the sending unit ot of the tank and at the bottom of the sending unit there is a screen if there is build up then use some air to blow it out,the fuel filter is on the bottom of the car on the driver side just in front of the tank on the frame
