vette coil springs on chevelle?
Bullcrappy
I need some stiffer oem type springs for a 69 chevelle.
i would think an vette had some stiff springs? would they work in chevelle?
what spring rate were they and more important will they fit the chevelle spring pocket? total diameter?
i want a 10.25 to 10.5 load height with about 400/ to 450 spring rate,,,
i could swing those but i just dont feel they worth the bank for buck unless you need the adjustability for height. which i dont.
and it is not a true coil over set up as the top of the spring/shock position is not changed and puts more stress on shocks. you really gain nothing other then nice looks/room and height adjustability. but no handling increase over a good shock/spring set up.
i may go with the single adjustable qa1 shocks after i figure out what springs im putting in...
the Eibachs 3856 are close..drop 1"/1.3" but at 500 lbs/in could be a little harsh on the ride. i really want 400/425 max
Not sure of your budget or what rules if any apply but they have what you want in a coil over shock form
http://www.spohn.net/shop/1968-1972...Pro-Coil-System-12-Way-Single-Adjustable.html
