Okay two issues one it throws a code for evaporator emissions control solenoid I replaced it and it still wants to throw the same code any suggestions my other issue is with my four-wheel drive I redid the ground wire cleaned it up which is underneath the side of the driver's side door on the front I also replaced the four-wheel drive actuator it doesn't want it takes a while for it to engage if it does it flashes a long time any other suggestions on what the problem could be I did notice a slight drip from the seal on the transfer case
